6080 Transmission |
rbaggett
Topic: 6080 TransmissionPosted: 21 Jan 2023 at 12:06am |
I have an 1982 6080 that used to shift easily but now is a bit stiffer to shift and if it gets in a bind like when driving through sand or pushing a bale fork into a group a round hay I can't get it out of gear on the gear shift and the range shifter. I tried backing off the clutch a little but that had no effect. Any ideas why this happens and how to fix it.
Posted: 21 Jan 2023 at 6:13am |
If it is only a problem getting out of gear, shut off the engine and if it then comes out of gear more easily, it is the clutch dragging.
DougG
Posted: 21 Jan 2023 at 6:34am |
I have stuck a WD 40 straw into the top of the shifter boots and sprayed lube on the shifter mechanisum- helped a bunch on mine
MACK
Posted: 21 Jan 2023 at 8:04am |
2wd or 4wd? MACK
rbaggett
Posted: 21 Jan 2023 at 8:22am |
It will not come out whether the engine is on or off. I have to move the tractor forward until I can pull the transmission lever out of gear.
rbaggett
Posted: 21 Jan 2023 at 8:25am |
It will not come out of gear whether running or not. I have to move the tractor until I can get it to come out
rbaggett
Posted: 21 Jan 2023 at 8:26am |
It is 2 wheel drive
MACK
Posted: 21 Jan 2023 at 8:35pm |
Are you sure it is full of oil? (check plug on right side of transmission ) Have saw shift rails gaul from lack of oil. MACK
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2879 |
Posted: 21 Jan 2023 at 8:49pm |
Is everything right with the clutch?
Crank end play? Edited by victoryallis - 21 Jan 2023 at 8:49pm |
Posted: 21 Jan 2023 at 10:00pm |
Mack has a very good point. Where are you checking the transmission oil ??
Orangeisgreat190
Posted: 23 Jan 2023 at 4:50am |
Check the clutch cable that actuates it. A friend of mine had a similar issue. The clutch cable had stretched enough that it would not take enough pressure off of gears to shift easily. Worth a shot. Hope this helps.
