6080 transmission + hyd. ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 6080 transmission + hyd. ???
    Posted: 14 May 2010 at 6:18am
Can you drain the trans oil on a 6080 without losing all the hyd. compartment oil? Or do they all share the same stuff;
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 6:24am
Hydraulic oil and rear end oil are the same and checked by dipstick on top side of PTO housing.  The transmission has a separate oil/compartment, level check is a plug on the side of the transmission under the platform.
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 8:16am
Ten years ago it corst about 7K to fix the trans after not refilling it because "a guy" changed the rear end oil and didn't know about the second check point......Make absolutely sure they are both full!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 9:50am
I seen the plug on the regular trans and back farther theres another, they are both full- but the trans oil looks alittle milky, dont like that ; just wanting to make sure  if I needed oil for the whole system or just the trans; and cant find my dam book on it ; Thanks !!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 10:05pm
I would change the tranny oil while you are at it.  When I did mine, the old oil looked green!
Larry Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Mo Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 12:50pm
be sure all boxs are full.WE FAILED to fill the range box and ended up tradeing the tractor off. WISH I HAD IT BACK.
Newacy24wel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newacy24wel Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 10:16am
Can you or does anyone have a diagram where this is/plug? 6080. I am trying to find on a manual... new to me. Trying to change the transmission hydrolic oil on by the pto. tractor is AC 6080 new to me. Thank you.
Edited by Newacy24wel - 16 Jun 2024 at 10:21am
This page was generated in 0.035 seconds.
