6080 starter |
cowkicker
Topic: 6080 starterPosted: 03 Apr 2025 at 3:12pm |
Gear reduction starter died on my 6080 so I put a direct drive starter from a 7000 on it to get going. The 7000 starter worked fine and spun the engine over great. My questions are, would you pay extra for a gear reduction? Where would be the best place to get a new one? Lots of price variations out there, what about quality? Thanks
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7539 |
Posted: 03 Apr 2025 at 4:53pm |
I an still running the original direct drive starter on mine. I just had it rebuilt last summer. Starts perfect every time.
Les Kerf
Posted: 03 Apr 2025 at 8:07pm |
I have switched several diesel engines of various makes/models to gear reduction starters and have found them to be superior in every instance. Your mileage may vary.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4144 |
Posted: 04 Apr 2025 at 6:03am |
Mine still has the original, Lucas, starter. It's been through the shop and works fine. If it dies, will look into a gear reduction replacement. If it's cool out, think under 60, I plug it in. Just 15-20 minutes helps a bunch, more as it gets colder.
Posted: 04 Apr 2025 at 6:30am |
I always used to keep two rebuilt Lucas starters on the shelf. Had enough cores to keep that going. When a Lucas was rebuilt or new, they performed fine. But, most of the time, they never held up to the years of service a Delco starter would deliver. I'm all in on gear reduction starters if I was replacing a Lucas just because of that.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3102 |
Posted: 04 Apr 2025 at 7:26am |
If its anything like the Oliver starters the gear reduction starters from places like DB Electrical are much cheaper than original starters and will start the tractor better.
