6080 hydraulic filter o-rings |
ksucat ![]() Bronze Level ![]() Joined: 13 hours 1 minutes ago Location: NE Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 12 hours 20 minutes ago at 10:27am |
Drained fluid and replaced filters on my new-to-me 6080 yesterday. One new filter (WIX 51831) was fine. O-rings for the second filter(WIX 51652) don’t have a good place to go. Both that came with the filter are larger diameter but thinner than the o-ring on the old filter, so I’m not getting a good seal. Did I get the wrong o-rings with this filter or am I missing a trick to hold them in place?
Thanks |
ac160 ![]() Silver Level ![]() Joined: 02 Dec 2010 Points: 391 |
Are you speaking of the longer filter? You might need to try a second O-ring maybe or a different one. The new filters aren't providing a good o-ring anymore and might be made slightly wrong. At least that is my guess from when I had the same problem on a 6070.
The Agco parts book shows the o-ring as a separate part from the filter, and only one ting between the filter and housing. Looks like I reuse the ring off the old filter and toss rings that came with the new.
