6080 FWD issues
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: 6080 FWD issues
    Posted: 10 Apr 2025 at 6:35am
It has 5500 hours. Runs and drives.
The good?
The bad?
Tires and rims are great. At auction now. One of the last ones built.
http://lonsallischalmers.com
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2025 at 11:15am
Link TO Auction:  ALLIS-CHALMERS 6080
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2025 at 11:54am
The bad?? FWA doesn't turn short at all on 30 inch rows. Better when set for 38 inch rows but they still only have one knuckle at each king pin. Not the best when cold starting. Just a matter of starting management ie: ether, block heater, manifold heater, etc.  The good?? Powerful and fuel efficient. Nice operating platform and easy on/off. Pretty simple to work on. No computers.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2025 at 5:13pm
We got 6 6080’s between uncle and I. The 2wd one's I really like the MFWD ones not so much. 16:1 compression ratio really helps starting. They make fantastic haying, fertilizer spreading and raking tractors poor loader tractors.
Edited by victoryallis - 10 Apr 2025 at 5:13pm
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 7:46am
Make sure it has the support on the front bearing. It looks like it has had the rear rims replaced from original, same with the hydraulic pump.  It needs a cab kit.
Otherwise as it has been said great tractors and easy on fuel.  On/off is very easy and nice.  Cold starting varies by tractor.  The block heater works good, but is a pain to replace.   For the price, it is currently at it is well worth it.  4wd is pretty decent as well.  If you put a loader on one, they aren't too bad, just make sure to have one going to the rear axle.
I have 2 6080s and a 6070.  I spent quite a few hours on a 6060 with 4wd.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 12:23pm
Late models do not have the front crank support  Internal modifications were made to prevent the thrust bearing issues.  Have not had any problems with mine yet.
6080fwa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6080fwa Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2025 at 11:54pm
I got a "newer" 6080 deutzallis with crank thrust bearings worn thru thrust bearings into the block, crank and block were junk....DO NOT TRUST THE INTERNAL THRUST BEARING, put a crank bra on it and keep pto lever fwd as much as possible.
I saw one at auction w bad crank endplay still running but oil leaks and clutch issues.
check crank endplay.
fwa tractor  will work as a good loader tractor, just dont go crazy. 2wd loader breaks steering spindles often.  They are good tractors, will start at -45f if plugged in out of the wind, bad delco ac comp change 2 sanden. most have 90-95hp...... solid tractor
d19d d19lp 175d 190d 190gxt 190dxt 200 6080 7000 8010 9150 9190
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2025 at 6:36am
Sold for $17250.
