6080 2wd tie rod end
977.3Ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Topic: 6080 2wd tie rod end
    Posted: 09 Jan 2023 at 12:32pm
Having problems finding the right hand tie rod end for our 2wd 6080. Agco part number is 70260801, the number is obsolete and my dealer couldn't cross it over to anything else. It looks like the 6060/6070 share a rod end with a 170/175, but nothing for a 6080. Is there a tie rod out there that will work or am i on my own to make a replacement?
Jimmy
1982 8050 Powershift
1982 6080
1992 R52 Gleaner
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 1:11pm
Have you tried 70260802?  It appears to be the full tie rod with both ends.  Also check with some of the sponsors on here.  Mcmaster carr seems to have some tie rod ends, but not sure if they will work.  I know some of them can get some hard to find items.  I am curious what you find out.  I have a couple of 2wd 6080s as well, but haven't had to change the tie rod ends yet.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 10:21pm
70260802 is no longer serviced by AGCO. I have been looking for a replacement on and off for two years with no luck. If you find please post so we can help others. It is also used on the 7000 with light axle. I had thought of moving cylinder to the left and welding brackets to the tube like the 7000 series did.
Albert
jrjuday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrjuday Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2024 at 11:55am
Has anyone been able to find these tie rod ends?
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2024 at 4:50pm
I have 21 of 70260801 tie rod ends I got made 295.00 plus shipping
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrjuday Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2024 at 9:19pm
Where are you located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrjuday Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2024 at 9:41pm
Can I send you a PM?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2024 at 6:31am
Yes u can    New Holland PA
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2024 at 7:01am
Aren't they basically a Fiat except for the motor? might try looking at Oliver 1365 ends.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2024 at 7:21am
Front axle was all A-C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2024 at 7:43am
Curious where you had them made
