6060,6070,6080 Brake fluid |
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5217 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Sep 2024 at 3:57pm |
Impossible to find the SAE10W-10 oil for the brake reservoir on these tractors. I have 1 in need of fluid that I’m repairing for a friend. What is everyone using? I was told Dextron 3 was an alternative?
Thanks Rob |
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 800 |
I use case IH 73344413 fluid
Thank you Alvin, I greatly appreciate your response sir. Hope all is well in PA!
Edited by AC720Man - 12 Sep 2024 at 6:09pm |
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4063 |
I added some to my 6080 some years back because the 'brake oil level' light would flicker. Remember it taking a long time to figure out what to use and don't remember what it was now. Only took about a tablespoon to make the light go out! Been fine ever since. Pretty sure I talked to. Reed at the farm store and he got me on the right track for what oil to use.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21816 |
I'm OK with any type of automatic transmission fluid.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87561 |
If they call it SAE10w... then that is a thin hydraulic fluid.. I would think, like the DR that Type F, or the old Dextron 1 or 2 would be good.... I might stay away from the MERCON LV or Dextron 6 typ "synthetic" heavy addative oils............. I have never heard of SAE10w - 10... that would be an oil that acts as 10w in the summer and 10w in the winter.. WHY put the -10 on the end ?
