6060 rear wheels
K bockting View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Topic: 6060 rear wheels
    Posted: 12 Feb 2026 at 7:59pm
Has anyone installed 34” rear cast centers off a 6080 on a 6060? i do know will need longer studs , bolt pattern is the same, center hole on 34” casr center seems to be 1/8” smaller than steel pressed 28” rim.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2026 at 8:26pm
Have a late friend that installed the 34's on a 185
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2026 at 5:50am
Have a cousin that has a 6060 with 34's off a 6080. Looks great! It came with the standard 28's.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2026 at 7:09am
6060 has a Fiat rear,Fiat 8 lug pattern is metric not like US built tractors.There were certain Fiat built tractors that came with adapters and US pattern wheel centers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2026 at 7:11am
Also double check the bolt pattern its very close but not the same on Fiat vs US built
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2026 at 9:12am
6060 and 6080 are both made by Fiat, so shouldn't be a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2026 at 12:13pm
I'm not familiar with those two models but on some older Fiat built tractors if pressed steel wheels were used they had the metric wheels but if they came with power adjust wheels some used adapters to use US size centers.Just to make life interesting Olivers 1450's could have 3 different wheel lug patterns.
cornel b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornel b Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 6:55pm
got some 34 in pressed cemters and power adjust wheels fron a 6060
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 9:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 9:34pm
Found a nice set. Thanks
