6060 rear wheels |
K bockting
Topic: 6060 rear wheelsPosted: 16 hours 16 minutes ago at 7:59pm |
Has anyone installed 34” rear cast centers off a 6080 on a 6060? i do know will need longer studs , bolt pattern is the same, center hole on 34” casr center seems to be 1/8” smaller than steel pressed 28” rim.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4582 |
Posted: 15 hours 49 minutes ago at 8:26pm |
Have a late friend that installed the 34's on a 185
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4250 |
Posted: 6 hours 25 minutes ago at 5:50am |
Have a cousin that has a 6060 with 34's off a 6080. Looks great! It came with the standard 28's.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3168 |
Posted: 5 hours 6 minutes ago at 7:09am |
6060 has a Fiat rear,Fiat 8 lug pattern is metric not like US built tractors.There were certain Fiat built tractors that came with adapters and US pattern wheel centers.
Gary Burnett
Posted: 5 hours 4 minutes ago at 7:11am |
Also double check the bolt pattern its very close but not the same on Fiat vs US built
