6000 cab wipers |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7616 |
Topic: 6000 cab wipersPosted: 21 Feb 2026 at 8:31am |
Question about the windshield wiper on the 6000 cab. Is the front wiper assembly (and mounting brackets) the same for the rear wiper? I am looking to put a rear wiper on the cab of my 6080, but they are almost impossible to find. Any idea if a front wiper can be used on the rear? I know the motors are the same, but I would still need the mounting brackets and other parts. Would the rear wiper assembly from an 8000 series be the same? Please let me know. Many thanks!
Daehler
Joined: 23 Nov 2010 Location: Lexington MO Points: 1176 |
Posted: 21 Feb 2026 at 8:04pm |
I assume they are the same. Ive only ever seen 1 rear wiper on a 8000 series. Rarest option there is except agri data but ive seen more of those than rear wipers
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
Mikez
Posted: 22 Feb 2026 at 7:39am |
Parts book has note under bracket, motor and mechanism. Qyt 2 with rear wiper. The wiper arm itself shows different part number for rear wiper.
Mikez
Posted: 22 Feb 2026 at 7:43am |
And different numbers in 8000
Jasonw
Posted: 19 hours 39 minutes ago at 7:23pm |
Yes the brackets and motor are the same. I recently added a rear wiper to rear of my 6080. I used a wiper motor and arm off of a 8000 series but wasn't able to find the mounting bracket either. I took off my front wiper bracket and had a local shop draw up the part and duplicate it. The wiring was already there in the cab harness for the rear wiper so extra wiring wasn't needed. I could contact the shop and see how much it would be for them to make more brackets if you are interested in getting one.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8919 |
Posted: 5 hours 39 minutes ago at 9:23am |
Does that mean both wipers work off of that same switch? I seen the existing wiring while doing light work on my 8000's.
DSeries4
Posted: 5 hours 8 minutes ago at 9:54am |
I believe so. I did see some existing wiring aimed towards the rear when I had the top of the cab removed several years ago.
