60 series plow parts
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: 60 series plow parts
    Posted: 22 Apr 2011 at 9:06am
I need 2 bearing caps for a concave cutter, tried trailer caps wont fit must be a special size. I thought some of you with the plow patrs booke could give me a part nimber to see if any dealer had some sitting on a shelf some where. Thanks. Randy
Will try to find the piow pic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 9:08am
Also did any of these come with a gauge wheel? My book doesnt show one.
Thanks Randy
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 10:34am
Model 64 semi mounted plow. Has the gauge wheel in the pictures.
Gauge wheel hub cap is 327531.
Coulter cap is 328279. Dimensions aren't given in the plow bottoms book. Normally the cap is the same size as the OD of the adjacent bearing cup. No doubt its metric. The adjacent cup is 211897, I don't have a cross to bearing maker's number.
Baum Hydraulics has several sizes of such hub caps, as does Shoup. I'm not sure either place's search engine can find them, but you can down load the Baum catalog by section, you want the section with wheel hubs. You want section F, look for grease caps. They have a wide selection. 20 sizes. www.baumhydraulics.com. At www.shoupparts.com search for "dust cap." Their results are less friendly.
But for both you need to know the size.
Gerald J.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 10:46am
We have a 70 series plow with that style coulter and I never found a cap that would fit and had to turn out a pair on the lathe.
This page was generated in 0.154 seconds.
