5-16 bottom hydraulic reset plow
JimVH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimVH Quote  Post ReplyReply Direct Link To This Post Topic: 5-16 bottom hydraulic reset plow
    Posted: 30 Apr 2012 at 8:17pm
Can anyone give me some help in checking the hydraulic pressure and operation of an AC monoframe plow?  I picked one up last week and have only dealt with the manual reset plows in the past.  I would like to confirm that it is operational before i dig up some rocks.
Jim VH
orange knight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange knight Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 9:16pm
You need to open the valuve and see how much pressure is on the hyd. side of the system. Should be between 1000 and 2000 psi. The pressure can be adjusted with the hyd. on your tractor.
952-290-1063
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 9:40pm
I  think that pressure is a little high, my book talks about 850 up to only about 1200, would have to look for sure, if you want let me know and I will dig the book out and look for sure.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2012 at 9:43pm
when I used to start a new plow in the field for a customer, I started at 1000psi and increased until the plow didn't reset when plowing and not hitting rocks or items. That you didn't have it set to firm and break something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimVH Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 6:43am
Thanks for your help.  I had the basics in my mind, but not the specifics.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 9:17am
Jim I ploweed with 2000's and in most of my soil I set hyd pressure to 750. I do remember some hard ground years when I needed more, like 1000 lbs. I also remember the time I had too much psi, the front bottom didn't release and I peeled half the front frame apart. That repair took lots of oxyacet and 2 big gussetts!
