5-16 bottom hydraulic reset plow
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=49858
Printed Date: 20 Aug 2025 at 3:01pm Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: 5-16 bottom hydraulic reset plow
Posted By: JimVH
Subject: 5-16 bottom hydraulic reset plow
Date Posted: 30 Apr 2012 at 8:17pm
Can anyone give me some help in checking the hydraulic pressure and operation of an AC monoframe plow? I picked one up last week and have only dealt with the manual reset plows in the past. I would like to confirm that it is operational before i dig up some rocks.
Jim VH
Posted By: orange knight
Date Posted: 30 Apr 2012 at 9:16pm
You need to open the valuve and see how much pressure is on the hyd. side of the system. Should be between 1000 and 2000 psi. The pressure can be adjusted with the hyd. on your tractor.
------------- Specializing in Allis Chalmers Tractor and Equipment Parts
952-290-1063
Posted By: jiminnd
Date Posted: 30 Apr 2012 at 9:40pm
I think that pressure is a little high, my book talks about 850 up to only about 1200, would have to look for sure, if you want let me know and I will dig the book out and look for sure.
Posted By: old farmer
Date Posted: 30 Apr 2012 at 9:43pm
when I used to start a new plow in the field for a customer, I started at 1000psi and increased until the plow didn't reset when plowing and not hitting rocks or items. That you didn't have it set to firm and break something.
Posted By: JimVH
Date Posted: 01 May 2012 at 6:43am
Thanks for your help. I had the basics in my mind, but not the specifics.
Posted By: captaindana
Date Posted: 01 May 2012 at 9:17am
Jim I ploweed with 2000's and in most of my soil I set hyd pressure to 750. I do remember some hard ground years when I needed more, like 1000 lbs. I also remember the time I had too much psi, the front bottom didn't release and I peeled half the front frame apart. That repair took lots of oxyacet and 2 big gussetts!
