5020 Final Drive Top Bearing
mightycondog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mightycondog Quote  Post ReplyReply Direct Link To This Post Topic: 5020 Final Drive Top Bearing
    Posted: 02 Mar 2024 at 4:06pm
I'm replacing the top bearing on the final drive.  The bearing is located under the steering arm and under the top seal.  The new bearing is covered on 2 sides and I'm wondering which is the correct way to press the bearing in?  Upon disassembly of the right side, I found there wasn't a bearing present.  I have the parts diagram, but it doesn't really show which way the bearing should be pressed in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mightycondog Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2024 at 4:21pm
The specific bearing in question is used for the steering and is located below the steering arm.
This page was generated in 0.039 seconds.
