4W305 Injector Tips
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Topic: 4W305 Injector Tips
    Posted: 04 Apr 2024 at 1:08pm
Does anyone know where I can source a set (6) of new tips for my fuel injectors?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 3:53pm
8000s had Bosch tips.  Maybe the 4W used Bosch as well?  I don't know much about the 731 engine.  I would ask around at some local diesel rebuild shops.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 4:11pm
Google 74396702 ....  Totally different from other AC tractors
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2024 at 5:38pm
Injection pump shop says NLA
Tbran is that the correct tip part number??
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2024 at 9:13pm
I googled it and some place - most come form reliance - $$$$$$$$$
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2024 at 5:35pm
Thank you, pricey it seems is the the way this engine parts have become....
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2024 at 6:09pm
I've gotten to where I'm having to clean and reuse a lot of these old obsolete nozzles. The old days of just replacing the tip automatically have come to an end. Many are not available anymore. As long as the tip is not pitted or holes damaged, they can be saved.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2024 at 6:19pm
Thanks Ed, my injection shop is hoping they can bring them back.  When he tested two of them in my presence they sprayed a stream of fuel, never seen that before when testing any nozzle, he said to me, they must be really worn badly.  Got my fingers crossed he can bring them back to life for me.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2024 at 7:43am
Possible it uses the same injectors as an 844 industrial engine?  might be able to locate some.  back in 2010 i had the injectors on my HD16 gone through and they called no parts available,  they asked about some machining procedure as last resort and i said do it cause iv got no other choice. it ran well till the crank broke
Edited by CAL(KS) - 10 Apr 2024 at 7:45am
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2024 at 6:33pm
Got my fingers crossed that the shop can get them to work.  Found three tips on ebay, got them coming, however I am not holding my breath they will be what I need, and if they are it still leaves three short.
This page was generated in 0.586 seconds.
