45 Pulling tractor
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 45 Pulling tractor
    Posted: 27 May 2015 at 6:23am
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 6:24am
What motor is in it? 3 carb setup must be fun to sync.
Charlie
BPM75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BPM75 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 6:40am
I'm not sure what motor it is, but wow they done a nice job on that tractor, very clean and well built.
59 D17 gas nf, 66 XT 190, 69 220.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 6:46am
That intake/header exhaust is a mint!
Is it a 292 motor?
Charlie
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 8:44am
If I remember it's a modified 302 GMC
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
VFDfireman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VFDfireman Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 9:01am
Is the handle on the right fender the throttle?
Not familiar with pulling tractors...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 9:11am
Yes the throttle is on the right fender. It's called a deadman as it is spring tensioned so that if you let go it pulls back so that the tractor does not "run away"
Man that header is a thing of beauty!
Charlie
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 9:11am
im sure somone on here will know whos it is does look sharp
Post Options Post Options   Thanks (0) Thanks(0)   Quote BPM75 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 9:23am
Description says engine is a 1952 525 cid
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 11:47am
wounder how many plows it can pull lol .
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 9:33pm
What class would that pull in??  Most non-turbo classes have an rpm limit and stock block rules.  I don't know what stock WD45 block could be opened up to 500+ cu. in.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Brian-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian-KS Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 9:59pm
Looks Good Thumbs Up
EAT BEEF!
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 10:26pm
wait it cant be a gmc 302  the ex and air intank is in the other side of the block right??
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 10:53pm
Well... unless they mounted the engine backwards... and they could have...
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 10:55pm
water pump is still in the front. and timing cover
 iv been lookin for about a hour know lol i give up im going to bed ha
Edited by acd21man - 27 May 2015 at 10:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 11:19pm
Perhaps and RD-501... with a taller valve cover?... nahh... lower block has curves around each cylinder. Hmmm...
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 11:21pm
I didn't even pay attention to which side they were...thought I had read it awhile back
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2015 at 8:06pm
7700 and a few mins left any1 guna bid on it lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2015 at 8:26pm
figured it out its a 503 gmc. i was wrong:(. didnt no they made them. look them up
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2015 at 9:16pm
That's a slick tractor. Didn't sell at 9200
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian-KS Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2015 at 9:50pm
I contacted him about the engine.
This is what he wrote back:
1952 gmc 800 class firetruck
factory 503 ci, now 525 ci, stock stroke.
EAT BEEF!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2015 at 10:49pm
Again, I wonder where you would find a class that you could pull that in (other than the mod classes where that engine wouldn't be competitive).
Mark
GTH-L Simplicity
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2015 at 11:11pm
I have a GM 235 CID in mine, but haven't run it yets!
