45 D head bolts |
Brian Jasper co. Ia
Topic: 45 D head boltsPosted: 22 Dec 2010 at 7:10pm |
Where is the pan leak? At the rear? On my 262 build, I put a thin bead of sealer all the way around the pan, the rear sealing ring, and the rear cam plug. If you have coolant coming up a head bolt, I'd be wondering if the block had cracks around the hole. My 262 block had cracks around 10 of them. Did you have your block hot tanked and magna fluxed?
BLee Mn
Joined: 12 Sep 2009 Location: Montevideo Mn Points: 680 |
Posted: 22 Dec 2010 at 4:07pm |
having problems with a couple head bolts seeping antifreeze, took them out and put thread sealer on , still leak, very frustrated , any suggestions, also cant seem to seal up pan gasket, have a few oil leaks, this is after a major ovh on engine |
Cowboy UP
