45 carb question
spartman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spartman Quote  Post ReplyReply Direct Link To This Post Topic: 45 carb question
    Posted: 31 May 2010 at 8:29pm
was working on my 45 and took the carb apart to clean it up.
The carb is a TSX 464
Thought I took a pic to show which jets went where, but I cant seem to find it.
I think I put them in right but thought I would ask the experts.
I put the jet with the larger hole in the bottom of the carb and the jet with the smaller hole in the top half of the carb.
It seems to run but seems to be running really rich.
Did I put them in the wrong spots?
Post Options Post Options   Thanks (0) Thanks(0)   Quote spartman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 11:00pm
Does anyone have an answer or a pic of this?
The 45 just doenst run right yet and I would like to eliminate this as a problem
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2010 at 5:50am
I would try to get a hold of Steve at Band B custom circuits. He might be headed to Dale's for the weekend. His number is 973-632-5596
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2010 at 7:21pm
Here is a picture from the manual; will it help?
Post Options Post Options   Thanks (0) Thanks(0)   Quote spartman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2010 at 9:09am
It does help, but what I need to know is does the jet with the smaller hole in it go in the top half of the carb or in the bowl of the carb?
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2010 at 9:36am
I can't tell w/o taking mine apart.....but you could try switching them and see if it runs better.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote spartman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2010 at 10:42am
Probably gonna have to do that.
Keeps varying between flooding and then acting like its running out of fuel.
Got a new carb kit in it but the float wasnt changed.
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2010 at 12:15pm
did you play with the fuel adjustment screw on the buttom? and the air fuel screw on top?
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2010 at 12:22pm
Maybe float needle stickin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spartman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2010 at 1:03pm
I have adjusted both screws in an attempt to get it going better, but so far not so good.
I suppose it could be the float needle, but it shouldnt be cause its new, but anything is possible.
