433t engine
lowell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Topic: 433t engine
    Posted: 23 Jan 2016 at 9:13pm
looking to put one in a rat rod
so do these engine have much problems ????
I was told they have balance shafts do they
thanks for the help
trying do some thing that some one else don't have there is a lot of Cummins in them
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2016 at 9:26pm
The 433 is a very durable engine. It does not have a lot of low end torque but has tones of reserve power at high idle. Don't know how it would do in a rat rod but should be cool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2016 at 9:32pm
it will be in a model a Tudor sedan that only weight about 2200 pounds
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2016 at 9:36pm
we donated one to a college and they put one in a chev corvett and set a speed record for biofueled powered class for a while. They do have a balancer. If you are going to do a lot of crusin' and limit the rpm to 2500-2600 leave it in - otherwise remove it as it turns 2X the crank speed and could very well exit the oil pan. You can live with the vibration.   Put a lighter flywheel on for acceleration. Turn up the pump, big injectors - AC or Bosch, run the lower compression early pistons , add an air to air intercooler plus the liquid with a separate cooler for the water and add water, alcohol, propane injection, carry a bucket to pick up spewed parts and have a unique rat rod. You could use the orange tractor theme or the Purple Power motif from the BIG AL truck engine - Lil Al ?
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2016 at 9:40pm
A 433 engine does have a balancer to help cancel the inherent vibration in all 4 cylinder 4 cycle inline engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2016 at 9:45pm
I would try to run it about 1900 to 2100 they make good mounts for the Cummins the 4bt will drive you right out a truck with out them the motor I found is a 1979 so one said to run a 301 turbo on it and put more fuel to it
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 12:36pm
what rpm should they run at I'm going to try some were around my place to take the pump to have them redo the gov on it and set it up higher if I can other wise I will send it out to some one
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 12:44pm
In a 6080 ,the rpm,s have to be above 1800 to get anything out of it, just my experience
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 1:03pm
but are you pulling any thing your tractor weight more them my rat rod I have be pushing more wind just trying to get thing so I can start putting together thanks for your guys help
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 1:33pm
Nope just the tractor weight, 9,000 lbs;
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 1:42pm
my car is about 2200
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 2:29pm
Just my opinion, but wouldn't put much hope in it
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 2:44pm
ok just trying to get it shorted out before I buy to may parts I would think 1900 to 2100 should be ok
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 3:28pm
Somewhere around here I have an article where someone took a NEW 1979 ford truck to an Allis dealer, pulled the 400 out of it and dropped a 433 in its place. Said it pulled just as good and got extremely good milage.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 3:31pm
That's Sam in Georgia on here. He was an old AC block man I believe. Put the 433 in, and a slide in camper, and took a trip to California and back and got like 25 mpg.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 3:42pm
there one in a 1972 chevy pickup on a another form I joined it but have to wait un tell they let me post http://www.dieseltruckresource.com/forums/general-diesel-discussion-92/tryin-put-tractor-diesel-truck-174962/
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 4:55pm
you do not have to do anything but back out the high idle stop to go to 2800-2900... 1600-2500 is normal...you are probably not gonna run much more than that sasfely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 6:15pm
ok thanks I have to have the pump worked on I need to change the governor on it and set it up higher
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 7:52pm
If you are pulling 1 out of a dozer, the later ones had heaver bottom ends than the earlier 1's. I cannot give you a serial number break or date when this was done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 9:44pm
the one I found came out of a 1979 f2
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 11:46pm
Find about an '82 Ford 1/2t 2wd pickup that has came originally with 300 six with SROD transmission and 215/70 tires. the rearend will be a 9" with 2.54:1 drive ratio... run taller tires... say... 33" diameter or so, but narrow tread, and it'll hustle down the road with minimal resistance and LOW crankshaft RPM.
I'd be most worried about the A's frame... they were well-employed to contain the substantially-weaker 40hp flathead... bolting an oil-burner to that frame will be certainly destined to find any flaws fast...
You are changing the front suspension, brakes, and steering, yes?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 2:14pm
unless it has been changed, that is an AC injector, low compression engine. Engine will be orange in color.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 5:11pm
Here some internet post about the AC 433 diesel swaps into pickups.
This link is about a new 1979 F250 that got an AC 433I swap at AC dealership. The guy talks about its mileage going from 6-7 to 20.
This link is from this AC forum site.  Lots of reading on it & some pictures.
This is a site for Cummins 4bt swap information. Someone is talking about gleaner f2 433I swap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 7:30pm
the one I found is orange
the frame I have is a 1 1/2 model a frame it is 2 incher taller then the cars or pickups
for a transmission I'm going with a five speed out of a pickup have a overdrive z542
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 8:15pm
couple pic one of my car and one of the engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 8:34pm
That is a lot newer engine than I have delt with. Should be the heaver bottom end. I have attended the Good Guys car show in Des Moines, every now and then you see one with a diesel. Good luck, don't get discouraged and give up on it. Please post pictures of your progress.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 8:49pm
he said it was a 1979 it is 6 hours away one way it will take some time to get together
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 10:11pm
Someone has been trying to sell a 433 on the Denver Craigslist for nearly a year.  Think they are down to $1800.  Look under Allis.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 10:15pm
Found this one for 1500.00
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2016 at 10:16pm
Just looked, it's no longer listed.
This page was generated in 0.339 seconds.
