430 corn head |
CCF
Joined: 15 Sep 2019 Location: Danville ohio Points: 45 |
Topic: 430 corn headPosted: 21 Dec 2023 at 3:32pm |
Any one have dimensions of 430 corn head main actual width, length and weight trying to get shipping quotes
Thanks |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3671 |
Posted: 21 Dec 2023 at 3:44pm |
need more specifics please.. Orange or black frame? BLACK 430 as follows: weight: 2400 lbs, width: 126.4 inches, length: early short snout ~ 105 inches, length: later long snout ~ 113 inches. Edited by AC7060IL - 21 Dec 2023 at 4:05pm |
CCF
Posted: 21 Dec 2023 at 3:46pm |
Black |
AC7060IL
Posted: 21 Dec 2023 at 4:21pm |
The A430 Black gleaner corn head is designed to be shipped horizontal(laying flat) or vertical( upright). Most US state's DOT allows trailer width up to 102" (8'-6") as non wide-load so can transport day/night hours within LOG hours. So if the 430's length of 105 or 113 inches is an issue, it can be positioned on trailer vertically. To do so, both lower rear jack stands will mount for horizontal or vertical positioning. In vertical position, a loader/forklift of some sort is necessary to load/unload it into/out-of that position on trailer. And then wooden support blocks under the corn head's upper throat frame can help eliminate/minimize any potential tin work damaged. And,, going to want a minimum of 4 chains to secure/stabilize corn head's 4 corners to trailer. Or, snouts could be removed & stored elsewhere? Transport by Sea-land container ~ vertical position. If height is an issue, then remove snouts.
Amos
Posted: 23 Dec 2023 at 10:20am |
Remove the front portion of the snouts narrows it up to esily ship without ovewidth permit layig flat
thats way i truck them
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Posted: 29 Dec 2023 at 10:32pm |
hang it over on the ditch side and drive.
If hiring a trucking company, best bet is have the snouts removed and the header left flat for transport. Im not comfortable going up on its back unless there is a mating header and they can go face to face. |
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
