426 Intake Manifold Spacer
Mark D. View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Topic: 426 Intake Manifold Spacer
    Posted: 19 Apr 2011 at 7:47pm
For Sale:
1" Aluminum Spacer between the Intake Manifold and Head on a AC 426. Increases the air to number 1 and 6 cylinders therefore increasing hp.
Asking $100.00
Call Mark at 989-574-8227
Miss Behavin - D21 Super Farm
Xcessive Tinkering - 190 XT Hot Farm Puller
Watch on YouTube - http://www.youtube.com/watch?v=J2TX1Af7aoA
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 7:52pm
Ok, I'l bite!
How does increasing the volume of the intake evenly across all cylinders provide more air to only two?
I am being serious, I don't understand the principles involved???
Thanks,
Anthony
Still in use:
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 8:45pm
SOLD!!
Because the air inlet to the stock manifold is centrally located, air moves more freely into the center cylinders.  Air has a harder time getting to the farther away cylinders therefore reducing hp.  air + fuel = power
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 10:18pm
I guess I don't fully understand, since the manifold is under pressure, maybe the restriction from the narrower ends is what you are trying to say!
Still in use:
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 6:43am
The further you move from the source the less pressure you have even with the short distance in a manifold.  Another issue is the air has more time and distance to build heat reducing pressure (density) even more.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 1:38pm
I'd have to see the data that supports the spacer idea on a turboed engine.Theory may not be reality.
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 3:41pm
It opens up the intake more so number 1 and 6 have a larger space to get air into them instead of pushing it through a little space it doubles it. Make sense?
Making a living farming with and working on Allis Equipment
