426 injection pump
TrentH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TrentH Quote  Post ReplyReply Direct Link To This Post Topic: 426 injection pump
    Posted: 19 Mar 2026 at 3:48pm
I have a combine motor in my 8050 that I used the stanadyne pump when I put it in. It started leaking fuel on the backside of the pump out of a large plug by the bottom towards the rear . Does anyone know what size wrench for the plug? I’m trying to avoid pulling it off to tighten it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 3:53pm
1 1/8" I think.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 4:44pm
We made a special wrench - bent with correct angle and the surface has to be ground FLAT - the nut is so thin the taper on a std wrench will not turn the nut but just jump off. For some reason the bottom plug and back nut that retains the advance spring will 'let go' on rare occasions. Many times the threads pull - maybe you will be lucky.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 6:34pm
Not related to your problem, but I noticed this on an 8070.[IMG][/IMG]20260302_151404_2026-03-19_18-41-32.jpg20260302_151409.jpg20260302_151404_2026-03-19_18-41-32.jpg
Edited by Lynn Marshall - 19 Mar 2026 at 6:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 58 minutes ago at 11:30pm
I got one of those. Chinese knock off Bosch A pump. It's better than the m100 but not as good as the Bosch A on my other 8070. It was built locally by a guy who knew how to make one perform. Governor and torque matters. It has retard notches in the plunger for starting. I don't think the fake pump has that feature because of how it starts cold. 30-50 degrees. The M100 started better before I switched them.
This page was generated in 0.118 seconds.
