426 engine swap
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: 426 engine swap
    Posted: 08 Oct 2018 at 8:43pm
Ok guys,I'm looking at swapping motors in my 210 with an irrigation motor.My original motor had a freeze crack in it and has been worked on but still leaks enough to peel the paint off the side on the motor and i'm just done with it.I have found another engine to put in it and know there will be some things to change from one motor to the other but thought I would pick my fellow Allis owners brains for any information about this project.
Thanks,
Kevin.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2018 at 8:52pm
All depends on what the irrigation is and how it is set up as far as front and rear plate.
Need to know more on doner engine.       MACK
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2018 at 6:20am
As MACK said  the number changes needed varies with the build and how original looking you wish it to be. Older 426 engines had cam driven oil pumps I believe that all 210s has crank driven pumps? oil pan is different in appearance and I dont know if switching from one type of oiling to the other is even possible? Switching the front cover is quite involved due to how the camshaft thrust plate is retained, some just built custom mounts to avoid having to change it but when we put a gen set engine in our 220 we did it without pulling the camshaft because we have the ability to machine a custom puller and pusher to remove and replace the gear.
Edited by Butch(OH) - 09 Oct 2018 at 6:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2018 at 6:22pm
The irrigation motor is an MK II 3700.I know there are things that will have to be swapped from engine to the other.I know that getting the hydraulic pump switched is somewhat of a chore too.Also know about changing the rear plate,Will have to something with the lower radiator hose as they are on opposite sides as well.Is the 3700 motor a pretty good motor as far realiability and durability.I think i'm going to pretty much make the ole girl a parade tractor,so not to concerned about looking original and have seen as most of you probably have to a couple of 210's and 20's with the bigger cooler on them and look pretty good I think.
