426 cam bearings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: 426 cam bearings?
    Posted: 25 Nov 2024 at 6:30pm
Does the 426 engine suffer the same as a 226 regarding camshaft bearings getting worn and a loss of oil pressure? I would guess probably but don't know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2024 at 6:37pm
Well, kind of, but I've never had to replace cam bearings on any 426 for low oil pressure. They are pressure lubed, unlike the 301 that are gravity fed oiling from the rocker arms. The 201/226's have a hollow camshaft that is the main oil galley. None of the newer engines are like that. Your oil pressure should be 35 to 55 psi at full throttle with hot oil working in the field. 45 psi is pretty usual. 35 might have me a bit concerned. 15W-40 oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2024 at 7:28pm
Well,about 42 hot working hard so I'll just live with it. 15w40
This page was generated in 0.110 seconds.
