426 8070 oil passage
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: 426 8070 oil passage
    Posted: 05 Feb 2022 at 9:51pm
uploads/963/drilling_2022-02-05_21-47-41.jpg
The main saddle was still drilled to lube the cam driven oil pump which exited in the early 210-220.  An ole Ac service rep suggested plugging this at any teardown.
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 7:30am
I don't have any good insight for you, but about 5 years ago, I overhauled my 8070 and noticed the main bearings for the top side were different and came with instructions and small round balls to plug a hole in the main saddle.  I didn't want to split the tractor to drop the crank.  My main bearing looked good on the top side.  So I just replaced the bottom halves of the bearings and and left it alone.  From memory, I think it said something about better piston cooling, but I really don't remember.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 7:40am
Two completely different issues. The 8000 series original design upper main bearing shells were discontinued 25 or so years ago. So, as a result, the upper main shells that are now provided need the piston cooling squirter holes plugged in the block to keep oil pressures within a specific range. You did the right thing on an in-frame OH. Just use the old upper shells.
Edited by DrAllis - 06 Feb 2022 at 7:41am
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 7:56am
That needs to be in the knowledge section
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 8:58am
I has been our experience that # 5 rod is the most susceptible to damage due to oil starvation, my buddy thinks this is part of the issue - I can't prove it but he said he never had a failure and oil pressure builds faster with the hole plugged especially after sitting a few days..  This is FYI
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 12:29pm
Any guess if Clevites bought in 2009 would have been made like OEM? That's what my 8070 got but I didn't do the work. Has 700 + hrs so I guess it is ok? #5 rod looked fine last summer when dealing with a leaking liner seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 12:31pm
He is of course talking about the old Generation #1 3000 series blocks. I've always blamed slow oil pressure build up due to the fact that both engine oil filters are empty from draining back, versus the Mark 2 engines having the oil filters unable to empty themselves when sitting around for weeks on end.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 6:08pm
  Exactly, thats why my Allis manual says to fill those filters after oil change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2022 at 6:10pm
   Steve Fisher came to the same conclusion awhile back on here.
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2022 at 8:00pm
Hey Steve I used Clevite kits to rebuild my 8000 series 50 and 30 the bearings were exactly the same as the original, no need for plugs.
rieg
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 8:18pm
Thanks for that....
