Print Page | Close Window
426 8070 oil passage
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=186242
Printed Date: 03 Apr 2026 at 8:17pm
Topic: 426 8070 oil passage
Posted By: tbran
Subject: 426 8070 oil passage
Date Posted: 05 Feb 2022 at 9:51pm
uploads/963/drilling_2022-02-05_21-47-41.jpg" rel="nofollow - uploads/963/drilling_2022-02-05_21-47-41.jpg
The main saddle was still drilled to lube the cam driven oil pump which exited in the early 210-220.  An ole Ac service rep suggested plugging this at any teardown.
Posted By: Gregor
Date Posted: 06 Feb 2022 at 7:30am
I don't have any good insight for you, but about 5 years ago, I overhauled my 8070 and noticed the main bearings for the top side were different and came with instructions and small round balls to plug a hole in the main saddle.  I didn't want to split the tractor to drop the crank.  My main bearing looked good on the top side.  So I just replaced the bottom halves of the bearings and and left it alone.  From memory, I think it said something about better piston cooling, but I really don't remember.
Posted By: DrAllis
Date Posted: 06 Feb 2022 at 7:40am
Two completely different issues. The 8000 series original design upper main bearing shells were discontinued 25 or so years ago. So, as a result, the upper main shells that are now provided need the piston cooling squirter holes plugged in the block to keep oil pressures within a specific range. You did the right thing on an in-frame OH. Just use the old upper shells.
Posted By: CORLEWFARM
Date Posted: 06 Feb 2022 at 7:56am
That needs to be in the knowledge section
Posted By: tbran
Date Posted: 06 Feb 2022 at 8:58am
I has been our experience that # 5 rod is the most susceptible to damage due to oil starvation, my buddy thinks this is part of the issue - I can't prove it but he said he never had a failure and oil pressure builds faster with the hole plugged especially after sitting a few days..  This is FYI
Posted By: SteveM C/IL
Date Posted: 06 Feb 2022 at 12:29pm
Any guess if Clevites bought in 2009 would have been made like OEM? That's what my 8070 got but I didn't do the work. Has 700 + hrs so I guess it is ok? #5 rod looked fine last summer when dealing with a leaking liner seal.
Posted By: DrAllis
Date Posted: 06 Feb 2022 at 12:31pm
He is of course talking about the old Generation #1 3000 series blocks. I've always blamed slow oil pressure build up due to the fact that both engine oil filters are empty from draining back, versus the Mark 2 engines having the oil filters unable to empty themselves when sitting around for weeks on end.
Posted By: NEVER green
Date Posted: 06 Feb 2022 at 6:08pm
  Exactly, thats why my Allis manual says to fill those filters after oil change.
Date Posted: 06 Feb 2022 at 6:10pm
   Steve Fisher came to the same conclusion awhile back on here.
Posted By: rieg
Date Posted: 09 Feb 2022 at 8:00pm
Hey Steve I used Clevite kits to rebuild my 8000 series 50 and 30 the bearings were exactly the same as the original, no need for plugs.
rieg
Date Posted: 11 Feb 2022 at 8:18pm
Thanks for that....
