4041 Help
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Topic: 4041 Help
    Posted: 28 Jan 2015 at 4:16pm
Have  a chance  to buy  a  4041 runs good but   bad  rear end  .  comes  with loader, tiller,  blade ,  backhoe.
  Whats  the  good  & bad   ??? Also  can get  a  4040  cheap  -- Parts  machine.              will   parts  enter change.  Thanks  Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2015 at 6:45am
Should be able to part either one of those machines out TC. Folks are always looking for a good running Onan for a replacement engine. I believe the 4041 Simplicity is the same machine as the 620/720 AC's. Parts I would think should interchange along with the implements. Not sure about the 4040 and what will interchange wit' dat one. Not familiar wit' dat model machine...
Short Round
fasstman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fasstman Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2015 at 4:56pm
Rear ends should interchange. I would like to get a loader and backhoe for my 720. Are you going to get them? I might be interested in some parts and pieces. If you want to sell some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2015 at 5:37pm
Will  keep  you  posted ..          TC
SchottEquipment View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SchottEquipment Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2015 at 2:30pm
the parts will interchange, except for the intakes  and crabs on the motor.
 the 4040/616 was a 16hp, the 4041/620, and the 9020/720, were a 19.5hp.
  the rest of the drive lines can be switched between models.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2015 at 11:26am
I'd like to find a back hoe for my 720.
Dusty
