'39 B part out or save? |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Topic: '39 B part out or save?Posted: 12 Dec 2010 at 8:26am |
I have a '39 b that runs very well but the block has been welded after a rod went through the side. It has 12.4/11x24 tires which I would like to use on my wc. It has an adjustable wide front which I could sell. It has one rivited wheel/hub that I need for my '38 b. I also could use the traney on a C that has a noise in it. The sheet metal is rough but not terrible. The engine is electric start with gen bosses. The starter is bad. It has an ugly homemade 3pt. I have a late '38 b that I plan on restoring and I could use lots of parts off of it. I've never parted one out and can't decide what to do. The motor was rebuilt when the block was welded and it runs good but the weld is ugly and not ac original. I have an extra block but no main caps. Thanks for any input.
Thad
Jeff Z. NY
Posted: 12 Dec 2010 at 8:31am |
With all the parts that you are going to save an use and the rest you can sell I would say the '39 is now an organ donor.
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 12 Dec 2010 at 8:32am |
You've certainly convinced me that it is a parts tractor, therefore, by the authority vested in me (which is none) I am giving you permission to go ahead and do what you want with it, without any repercussions.
ChuckLuedtkeSEWI
Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Posted: 12 Dec 2010 at 9:14am |
Did 39's come with electric start? I thought it was 40 that electric start was an option so it sounds to me that the motor was changed out. If it has a good early gas tank, you may want to hold onto that as the rear mount? changed and the earlier ones are harder to find in good shape and can fetch a good penny. I bought a 39 once that the engine was tight and it was in pieces only because I wanted the cultivators that came with it for my 40 B. I think I paid 300 for the whole thing, and I got 250 for the gas tank alone on ebay.
I wouldnt' feel bad parting it out, but make sure you keep a good spare of everything that you can, as it always seems that I sell something and then a year or two later, something else on another tractor takes a crap and then I wish I would have kept it on the shelf. Then again, the parts I have on the shelf have been sitting there for years and I never seem to need them. Oh well.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
AC WD45
Joined: 28 Sep 2009 Location: Mid Michigan Points: 2078 |
Posted: 12 Dec 2010 at 9:28am |
Always remember this though: If It's got a frame, It can be restored.
I'd rather see thisone parted out than some perfect tractor like I've been seeing lately.
German Shepherd dad
Thad in AR.
Posted: 12 Dec 2010 at 10:31am |
Yes the electric start was added the tool box is a crank start that has been cut for a battery box and it does have the old type gas tank but I will use it on my 38 because it's very clean and has never rusted. It has a distributer on it that I put on it. It also has one 5 bolt rear hub with b splines inside and a flat b center instead of a dish center like a c. It has a electric start torque tube.
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 12 Dec 2010 at 10:48am |
sounds like you bought a parts tractor frt. wheela re different on a 38[cast] 39 [rivited]
wjohn
Posted: 12 Dec 2010 at 11:19am |
I agree. Even though I'm partial to '39 B's I think it sounds like it's far enough from original that it might be better off used to restore your '38.
Thad in AR.
Posted: 12 Dec 2010 at 2:26pm |
It's a late '38 b I'm wanting to restore. I've been told the rivited hubs were original on a late 38 is this true?
ChuckLuedtkeSEWI
Posted: 12 Dec 2010 at 3:00pm |
Thad, here is a link to a previous thread talking about the riveted hubs, and the rear wheel differences.
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 12 Dec 2010 at 7:05pm |
You know, I have trouble "parting out" any running tractor, especially a B. Remember, they don't make them anymore. Any one lost is one lost forever never to be replaced.
However, I cannot tell anyone what to do with their property.
Good Luck!
Bill Long
Ken in Texas
Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Posted: 12 Dec 2010 at 7:37pm |
Sounds like it's more of something other than a B with a 39 serial number. They get that way over time with several owners. Not much difference in a late 38 and a 39 when new.
GlenninPA
Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Posted: 12 Dec 2010 at 9:06pm |
The rivited hub/rim ran from '38 (#9019-11799) to '39 (11800-26524).
Brian Jasper co. Ia
Posted: 12 Dec 2010 at 9:53pm |
I'm with Bill on having trouble parting out a running tractor. I once bought several Wisconsin AK series engines for parts. Next thing I know, more parts show up cheap and now I have 8 of them that run good. I think I'm down to just a good used crank and a flywheel housing...
