38's on WD
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Topic: 38's on WD
    Posted: 04 Jun 2016 at 10:39pm
Wanna put 15.5-38's on my WD, what has everyone done for wheels?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 5:21am
most I have seen run 8-9 bolt adapters.  seems like there are alot of cap bros wheel centers out now too.   if you go with an adapter, you can sell your wheels easier if they dont work for you, as you wont be selling to AC guys only.  i cant say i have seen any  non AC guys adapting 8 bolt wheels to 9 bolt hubs but i suppose its possible.
you will be lighter with an 8 bolt center vs one with adapter, but not many 38's on 8
Edited by CAL(KS) - 05 Jun 2016 at 5:23am
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 5:26am
I made my own
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 6:02am
Oliver pressed centers with 9 bolt adapters
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 8:00am
Some of us cut out the 9-hole center and weld in an 8 bolt center. When you run 3500 lbs, I need everything lightweight, and those 10 or 15 pound adapters ain't in the program. Resale value?? I never sell wheels, and surely not to a brand X competitor.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 8:14am
I cut the 9 bolt centers out and welded new 8 bolt centers in
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 9:40am
Ok, I'll be running 4500 and 5500, so weight isn't an issue. Where would a guy find the adapters?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 10:25am
Cap Brothers has them
Charlie
alchpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alchpuller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 5:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote alchpuller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 5:15pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 6:44pm
Massey Ferguson 85 tractors had 38" rims and an 8 bolt pattern same as a
WD.Also some of the newer tractors around have 38" wheels with 8 lug centers
don't know if the bolt pattern is the same or not.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 8:02pm
original wc spoke wheel centers,extended out to reach 38 in.rims
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2016 at 10:30pm
I just bought some 8 bolt repair rings and cut out the 9 bolt pattern, welded them in. Link imp in Ridgeland had the 8 bolt rings and they're cheap, don't rember but $30-$40 sticks in my mind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 11:08pm
That's a lot cheaper idea. Adapters are $350+ shipping.... reinforcement rings are $63.. just gotta trust my welding now!
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 8:45pm
Thompson used a 38 inch 9 bolt wheel. They won't be light.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 9:56am
Originally posted by patrickmull patrickmull wrote:
I made my own
Patrick. Nice job. Those look great! I would of liked to watch you do that.
Mike
