371 jimmie engine from hd 6 to hd 6
shanksmare View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shanksmare Quote  Post ReplyReply Direct Link To This Post Topic: 371 jimmie engine from hd 6 to hd 6
    Posted: 02 Jan 2020 at 12:45pm
was looking at swapping a 371 jimie engine from hd 7 in to an hd 6 with a 4 cyn budda are they fairly easy to swap?
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 9:02pm
I have seen a 3-71 put in the HD5 which is the same rear end and such, slightly shorter front than the 6 I think. Clutch may not bolt up. If a dozer should be easier than a loader. Engine may move back toward operator slightly but I think it is doable.
Lee Bradley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee Bradley Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2020 at 3:23pm
You will need to find a clutch assembly like the HD-5 uses. Output from the clutch to a driveline. The HD-7 engine bolted to the transmission bellhosing and the clutch was on the transmission input shaft. No driveline in the HD-7s.
