37 wc dowel in rear hub
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 37 wc dowel in rear hub
    Posted: 24 Apr 2024 at 10:14pm
my 37 wc has one dowel in the left hud and five studs .  does the dowel pull straight out or thread out ?  or deas the hub have to be removed to get it out from the inside ?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 6:28pm
Parts Catalog doesn't illustrate the Dowell as having threads, appears to be a press fit in to a blind hole.
G
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 7:36pm
I’m pretty sure that it screws out. We never tried to remove the studs from our ‘37…but our ‘38, ‘39, & ‘41 WCs , as well as our ‘39 RC all have tapped threaded holes in all six holes. I’d try a small pipe wrench or one of the outside “gripper” type stud extractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2024 at 10:43pm
my right side has six studs  itryed screwing it out had to use the rose bud on it i turned it several rounds it dont screw out  i will weld a nut on it and hook it to my 50lb. slide hammer on it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 7:07am
What’s the part number. I’ll see if we have it and check it out
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 8:51am
Curious as to why you what to remove it .
nonetheless ,still dead.
This page was generated in 0.177 seconds.
