360 out of a 226
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 360 out of a 226
    Posted: 15 Oct 2013 at 7:31am
How much stroke does a 226 take to get 360 cubes?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2013 at 8:19am
Bore of 4.630" and stroke of 5.375" gets you 362. Cannot stroke a 4 inch bore enough to get 360.
WildBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2013 at 8:26am
murphysmotorservice.com
go to murphys website and use his topic shop math.. pretty easy to use and find the math for cubes and rod lengths etc.  !! Jeff is a good guy to deal with . i use his rockers on all my pullers !
good luck Charlie 175 !!
Allis fan for life !   B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2013 at 8:48am
Thank you.
I must have heard wrong, I guess he said 260 which would be 4x5.25
Is this a common stroke?
As you can tell I know little about stroking rods and such.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2013 at 8:58am
no replacement for displacement !  hee hee...
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2013 at 9:05am
I've put togather a few cheaper engines for guys at 4.155 bore and 4.28 bore and 5.4" stroke doe 295 and 310 cid. These engines don't require verry expensive parts and little machine work. Then I've put togather some pretty expensive ones with billet parts.
An offset ground crank and some Buda rods would get 4.85" stroke by the time the crank is cleaned up, with a 4.125 typical overbore sleeve would get a 260 cid engine.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2013 at 8:33pm
I have 4.7 bore and 6 inch stroke in a 226 block
phil
