341 C.I. Piston and Sleeve
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Topic: 341 C.I. Piston and Sleeve
    Posted: 17 Mar 2015 at 10:09pm
New engine kit ready to ship. No block boring required for the 341 inch kit. Drop in and go.
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2015 at 9:24am
how much?
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2015 at 9:50am
Whats the compression ratio?
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2015 at 1:23pm
Send me an email at opsheads@hotmail.com and I can send you a price sheet.
Static compression ratio is around 14:1 depending on valve recess. That can be raised or lowered if need be.
bmartin55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 9:54pm
O.p.s.heads ..I sent u a email ..need to hear something. .thanks.bob martin.. bmartin5566@yahoo.com. .
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2015 at 6:56am
I hate to ask a stupid question, but I assume these are overbore kits for the 301 (2800/2900)?
Are these rebuild kits strictly for pulling or are they for field tractors, too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2015 at 7:57am
Designed to fit directly into a 301 block and yes for pulling engines.
This page was generated in 0.191 seconds.
