301 sleves
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Topic: 301 sleves
    Posted: 23 Jul 2018 at 11:43am
Looking for a set of sleeves and pistons for a 301 with a 3.75 yeah it's smaller we have a 280 cubic inch limit going in a wd45 3500 lbs our club is 17 mph other club is no limit
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2018 at 2:08pm
I think there's a jd sleeve that fits but I don't know the first thing about green stuff any help
Shawn PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2018 at 11:07am
Deere 466 sleeves will fit in a WD block but they are some work to do them.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2018 at 6:30pm
What kind of power will you get with the WD.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 9:04am
Mine was a 17 block bore was 4.625 and 6"stroke made 115 with basically stock head carb and manifold.
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2018 at 1:29pm
HA, Bradley gas or diesel ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2018 at 1:51pm
A 180 gas sleeve is 3.75, but the 180 had a shorter stroke crankshaft, so the pistons won't work. They were 265 cubic inch, i don't think AC ever built a diesel 265 cubic inch,or a 3.75 bore with 301 crankshaft.  GOOD LUCK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 6:41am
Diesel the 1 running in the class now used the gas sleeves and diesel pistons and cut the outside of the Piston down and recut the rings that's gives you 281 cubic inch going in a WD at 3500 lbs
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 6:54am
I thought your cubic inch limit was 280 ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 8:17am
It's supposed to be on economy class so the 281 they said they would let that go otherwise to get rid of that one cubic inch do you have to do custom sleeves and custom Pistons
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 11:38am
The guys I talked to that have done this to a 301, used the 265 gas sleeves and then turned the 301 pistons to fit, fairy simple fix. With the small sleeves and the longer stroke of the 301 diesel it works out.
Pullin With AC
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2018 at 11:42am
I can help you out with the machine work if you decide to try it
Pullin With AC
This page was generated in 0.111 seconds.
