262 diesel
Message Reverse Sort Order
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Topic: 262 diesel
    Posted: 06 Feb 2021 at 10:25pm
I ran 15wX40 in my series 4 diesel year around. I only used it to feed livestock in the winter. I always put out enough big bales to last at least 2 weeks. Then I could usually find a warmer day to put out more hay. Tank type water heater is a must in the winter.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 6:41am
I'm by no means an expert but I run 15w-40 motorcraft super duty in my wd45d.It only gets run in warmer temps. If you're starting this in less than 40 degree temps then I would drop to 10w-30 diesel grade,15/40 gets pretty thick in cold temps.You need to remember the oil pick up has a fine mesh screen on it which makes it harder to get the oil drawn through at colder temps. Honestly the 10w-30 would probably be ok year round.My operators manual for my 45d says 30w for summer and 20w for winter but that was old technology from back in the day.
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 8:52pm
Was wondering what’s the best weight of oil to use in a 262 Buda-Allis diesel?
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
