262 diesel parts
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Topic: 262 diesel parts
    Posted: 27 Nov 2009 at 7:17pm
Hi, I am looking for parts to convert my 262 gas to a diesel.
Does anyone have a complete diesel cylinder head, front timing cover, injection pump,  injection lines and injectors?
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 6:21am
Can you use the 230 ci Buda engine parts? if so, I can supply what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 7:29am
I wonder if that would work?  Do you just have the parts or a complete engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 10:45pm
Contact Tony at Tony's Tractors. I believe he parted two 45' Diesels this summer. He could probably help you out with a lot of parts....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 10:55pm
BTW, just saw a post from Chris/CT has a lot of 45D parts for sale. Contact him also!
Steve@B&B
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2009 at 11:45pm
Matt...I have two complete D17 engines and a parts pile....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 10:04am
How much do you want for one of the engines?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 4:28pm
I don't think the 230 parts will work. In the D17D repair manual they show both a WD45D (230) timing gears and the 262 timing gears. The shape of the covers don't look the same. The injection pumps are different, not to mention on the D19 and later D17 the water pump is on the block, not the head like the early 262 and 230.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2009 at 6:50pm
I have a D19D head that was on a running tractor that was burning oil.Would have to check on the injection lines no pump.In central VA
This page was generated in 0.161 seconds.
