2300 disc help |
rudyk ![]() Bronze Level ![]() Joined: 20 Apr 2016 Location: camdenton,mo Points: 151 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Nov 2017 at 3:51pm |
Looking at a 13' 2300 disc
Needs a bearing for sure, he says the others are good all blades look good Any opinions or rough value estimate All info is greatly appreciated |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8736 |
The bearings are still available. And the spools are to.
I bought one maybe five years ago for I think $6 or $700. It needed more then I thought. The rear sets still had original paint but the fronts were bad. Both gang bolts were bent, I put ad in old allis and scored one NOS and one used, then I bought new bearings and blades, it had been used all loose so some of the spools were wore bad as well as the center spacers, I think only needed two spools. I took and picked out the best spacers and only replaced the worst ones, like one or two on each side. The one side I took and cut down blades to use as backing plates and the side I got the used gang bolt he sent me some with it. Now inside the spacers between bearings there's a square tube that the blades go on. I just went to iron shop and got what fit the gang bolt and inside blade. Think I covered what I did, and now I have a good sound set of discs, sorry was long winded Edited by Mikez - 14 Nov 2017 at 4:11pm |
Did it turn out to be a good disc for ya
Yea they work good
Tim (Cent.WI) ![]() Orange Level ![]() Joined: 19 Sep 2009 Location: Stratford, WI Points: 214 |
I bought a pretty nice 15' last year for $750.00 needed one blade, I diced over 150 acres with it and it worked great.
On another note I saw a smaller one, I think it was a 13' go for somewhere around $1300.00 this fall at an auction. The smaller ones usually go a bit higher.
