230 gas block in diesel
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Topic: 230 gas block in diesel
    Posted: 09 Mar 2017 at 4:12pm
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 4:42pm
boy'' she looks nice' steve ClapClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 7:51am
click on the picture and you can see all photos
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 11:48am
I really like your front weight bracket. Gives me an idea.......
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 1:39pm
ok, time to give me my tractor back, I only left you barrow itTongue.  very very nice machine.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 2:52pm
Yes, really nice looking machine
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 8:09pm
Why the smoke when it's supposed to be a gasser. Just askin'. Sure does look good. I don't think I would have had enough nerve to put it in the field.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 6:16am
Gas block but it is a diesel. Looks like it has block mounted water pump and you blocked the water pump mount on the head. Does this combo works well?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 6:57am
230 gas and diesel blocks are the same. There was some gas engines that had the two oil filter boses casted on block but not drilled for 45 diesel.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 9:34am
WE also used a 262 gas block for a D-17 diesel rebuild and friend used a gas block used in a D-19 diesel rebuild
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 2:49pm
Well I'll be darned. Could a 292 be done the same way? And I guess you could just leave it a gasser with no problem.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 10:04pm
292 was a GM.     MACK
