226 common stroke numbers
Robacpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 4:21pm
I am going to waterloo iowa in February though. Weather
permitting it is much closer for me 2 hrs.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 7:10pm
so how many cubes , or bore on a 226 when it has to be poured solid ? and what about the head would some areas make for more porting ? bigger?    thanks hud
joetom08 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joetom08 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 8:21pm
Im building new motor now it will be 4 5/8. There is not much block left between sleeves so I'm going to rocblock it up to the bottom of water pump. Hope it holds together
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 6:52am
Originally posted by HudCo HudCo wrote:
so how many cubes , or bore on a 226 when it has to be poured solid ?    thanks hud
A good thing to remember when modifying engines for performance is that few questions such as those have a definitive answer. When I built custom rifles I was often asked "how far can I push speed before I get in trouble?" and my answer was always the same. Add powder one tenth of a grain at the time until it blows and then back off a couple.Wink The smart knew what I was saying, the dumb would ask how the heck can that work???
Same thing applies to building a hi-perf engine, if you run into an "expert" who claims different be careful about what you take as gospel from him.  Marty (WI50) has always been good about pointing out power vs longevity and I am sure he willc hime in with an answer you can take to the bank.
 Some here boast about how big they build  and might say "X" sleeve thickness is it,,,yet at the same time they sit on the sidelines among piles of busted up parts. The big gun mentioned earlier that won a class at Tunica is currently not running. How thin were his sleeves/ maybe the so-called expert will clue us in but what I know about the Allis block I would have to say DAMN thin. It was obviously hard blocked BUT hard block has it limitations too. Did his oil ring collapse or did his tin foil sleeves fail? I have my guess but that is all it is based upon experience with other engines that had very thin sleeves and hard blocked to back them up. Fact is you cant run tin foil for sleeve material and depend on hard block to save your dreams from destruction on past the test stand.  If you are doing nothing but pulling then hard block has many pluses but also carries some baggage that cannot be ignored, Marty also has made mention of that.
Edited by Butch(OH) - 16 Dec 2016 at 9:20am
cms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cms Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 9:35am
Holding the sleeves are no problem. What everyone forgets is how to hold head on.
mgburchard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 8:44pm
A person who's never built a big engine can speculate things to death as Butch does. When you hard block a engine the piston manufacturer will tell you to open the piston to wall clearance up .Most of the time it opens up double of what a machinist is use to going by the dimensions provided on the manufacturer box piston are supplied in .
Edited by mgburchard - 11 Jan 2017 at 8:45pm
This page was generated in 0.441 seconds.
