226 Camshaft
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: 226 Camshaft
    Posted: 14 Nov 2009 at 8:51am
I don't know about the 17's, but the WC has a bolt and jam nut in the timing gear cover. Adjusting that bolt, sets the end play.
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2009 at 9:23pm
Can anyone tell me if there is a end play setting for the camshaft, and if there is how do you set it. Or does the cam gear keep it in the proper location. I had the teeth wiped off of the cam in the D17, and no sign of the pump seizing. I checked the block that came out of that tractor originally and found the teeth off of that cam to. I guess that's why the crank journals are a nice blue color. Is it just 60 year old parts failure or is this a common problem.
