220 Turbo
shaunAC220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shaunAC220 Quote  Post ReplyReply Direct Link To This Post Topic: 220 Turbo
    Posted: 03 Jun 2014 at 5:09pm
will a turbo off a 7080 keep up with a roosamaster with a .450 head on it, putting out 400cc of fuel?
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2014 at 5:41pm
It will run with a 7080 turbo. It will run a lot better with something newer.
rowcropmafia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2014 at 6:26pm
There are a lot of better options out there to be had for very little money. With a little more info someone here could probably help you find exactly what your looking for. If your running somewhere near stock rpm. I would think a Holeset HX 35 or 40 would be pretty close to what you want and those can be found pretty cheap used off a 5.9 cummins
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2014 at 6:58pm
Need bigger than a hx35 or 40. More like a Hx52 or a S300 with a 64 to 66mm inducer.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
