220 transmission bearings
cdreb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdreb Quote  Post ReplyReply Direct Link To This Post Topic: 220 transmission bearings
    Posted: 11 Feb 2010 at 2:12pm
If you guys had to guess which bearing would be the most likely to fail in the transmission or rear end? I took off the trans filter and noticed metal in the oil of it. I have not used this tractor any at all just moved it into the shed to start fixing small issues front pivot bushings, checking rods and mains ect, Thanks CD
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 5:48pm
Just a quick comment.  It may not be a bearing, more likely the hardness coming off a gear. - AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 8:14pm
I had a 220 and a D21 that both failed the rear mainshaft brg on the front (4 speed) transmission. Symptoms were noisey in 1-2-3-4 and quiet in 5-6-7-8. Also had a D21 that failed the RH differential carrier brg, but I think the 220 is a bigger brg in that area and has a splash shield to direct oil to it better than the D21.  If there isn't any noise, I'd not worry.....yet.
