220 pto hollow shaft
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Topic: 220 pto hollow shaft
    Posted: 10 Mar 2016 at 6:50pm
Working on a 220.  The pressure plate splines were shot and looking at the hollow shaft that drives the pto the teeth are about half worn out.  Is this part available?  Anyone have one?  Looks like its AGCO part #70253242.
Also, I measured the fly wheel to check for wear.  I was told it should be 2.042.  Mine measures 2.049.  Is seven thousands enough to worry about?
Thanks!
Edited by Joe(OH) - 10 Mar 2016 at 6:52pm
Life is simpler when you plow around the stump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 7:01pm
Hi-Capacity clutch rebuilders(Iowa) can probably refurbish it with a new splined end and then change your pressure plates hub to match the new repaired shaft. They'd likely make it the same as an IH 10-1466 tractor, which are commonly repaired like this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 7:56pm
Doc, do you know if it can be removed through the torque housing or will the transmission have to be removed?
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 8:02pm
Joe, the hollow shaft will come out the front.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 9:13pm
If you replace the clutch, have the flywheel resurfaced and new pressure plate.    MACK
