220 front end
Riggs/Ia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riggs/Ia Quote  Post ReplyReply Direct Link To This Post Topic: 220 front end
    Posted: 08 May 2010 at 3:48pm
Does anyone know if the front oscilating pin is pressed in or is that suppose to be loose with a couple thousandths clearence? Had a 10ton portapower and a 25lbs slide hammer on the front and did not move at all!!! Can't heat because the sleeve is in the front end and can only see the end 1/2" of it. Had to take whole front end off and air-arc it out and have a new one machined. If anyone ever did this let me know, Thanks in advance Mark
Luke R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke R. Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 6:33pm
I thought they had a bolt that went thru them to hold them in place, at least thats the way it is on a D21 front end. It might be different for a two twenty front end. I took the whole front bolster off of our D21 and put the wish bone in a big press we have at work and it pushed it right out. Im almost positive their is a bolt that holds it into the front wish bone. I have been wrong before though LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riggs/Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 7:18pm
yes there is a bolt that holds it in but the main pin is so tight i had to air arc it out and when i did i beat on it with a sledge hammer and it just bounced off of it. just was wondering if it might be pressed because it was so tight in there!
