220 brakes |
fastallis
Joined: 13 Nov 2010 Location: Avilla indiana Points: 172 |
Topic: 220 brakesPosted: 25 May 2018 at 4:04am |
Yesterday my dad was working the 220 with a vertical tillage tool. He did close to 40 acres. When the right brake started to get really Hot. The tractor doesn't pull to the right at all and it still actuate fine. I loosened the pedal adjustment after it cooled down. Took it down the road a bit and it was warming up again. I put relined disc on a couple years ago new springs and balls. I chisel plowed last fall no problem. I don't have time to tear it apart now. What could be going on? I hope it didn't burn up the shaft seal? Has anyone had this happen? Thanks
Edited by fastallis - 25 May 2018 at 6:06am |
Posted: 25 May 2018 at 3:33pm |
Did you grease or anti-seize the ball pockets and the machined rub pads on the O.D. of the plates ??????
