2-12 plow depth link |
560Dennis
Topic: 2-12 plow depth linkPosted: 28 May 2025 at 7:22pm |
My model 4 has long rear landslide.
My question is about the link that goes from the axle lift to the depth control lever( left side in Tractor seat) . I cannot lift the plow with lever to plow a 6 inch depth furrow. I’m going to deep. The lever is all the way down locked. I was told that the model 2 has a link with three holes in it. If you’re familiar with that plow could you please verify that. I would also like to know the distance between each hole ? This would be a great help. I measure mine and it was 17.5 inches approximately center of holes in link rectangle lift bar . My manual sayes that the tires should be 5.00-16. ( 25.5 outside diameter) I currently have 4.6-16 motorcycles tires which are not quit 25 inches out side diameter. Thanks for your comments |
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2307 |
Posted: 28 May 2025 at 9:20pm |
I think I have the same plow, will check tomorrow and measure.
I think that is what mine is, it measures 17 inches hole to hole, I have 6.00 16 tires off a WD on mine and it works fine. Edited by jiminnd - 29 May 2025 at 11:00am |
