210 oil psi...
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Topic: 210 oil psi...
    Posted: 03 May 2011 at 6:24pm
The light came on today so I shut it down instantly, and after they revived me from the stroke I had, we restarted it and noticed a steady 30 psi at idle and 60 plus at high idle on the manual gauge. SO... what psi  is the factory sending unit supposed to be set at? Maybe the warning light sending unit goes bad?? Anything in the system I should be looking for? Thanks for any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 6:31pm
Probably should state this also.. I was not working it, only been idling for maybe ten mins, when i got back on it i noticed the light on. Had it running earlier with no issues.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 7:32pm
Check for a place where the wire has had the insulation rubbed off, like where it goes over a steel line or through a gap in the sheet metal.  I want to think that my service manual for my 7000 with a 301 says it's like a 3 or 5 psi cut-on for that switch (which means that it simply grounds the wire so you have a completed circuit through the bulb).  I'm not familiar with where the sender is on a 426, but it should be somewhere on the block where the oil gallery is.  The 301 has it tucked away behind the fuel filter and it's a pain to see and get to.  To check the switch, see if you have an open circuit when the tractor is running (resistance is infinite between the lead on the sender and a ground).
Hurst
1979 Allis Chalmers 7000
5800 Hours
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 8:01pm
sender on a 210/220 is at right rear of block right ahead of  rear plate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 9:26pm
found the sender. dont have time to get into it much tonight, but Hurst I hope you are onto something. Ive had engines spin bearings etc. before and it runs and sounds fine... but, I also hope I can trust the gauge. I just changed the oil with new 15-40 maybe  10 hrs ago
