210 engine rebuild vid
 Post Reply Post Reply Page  <123>
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 11:39pm
I use 3m silicone paste for sleeve orings. Was thought that in tech school and have rebuilt a lot of engines that way with zero issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 5:57am
How many 426 A-C non-piston cooled engines have you done ??
cdreb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdreb Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 2:06pm
I was still trying to get enough money for an overhaul for this 220 I have. All overhaul kits need to be honed to get enough piston clearance for a non piston cooling engine?
I was still trying to get an Clevite kit...
B,C,5020,D17,(2)-190XT's,220,D21,7060, Agco LT70
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 2:23pm
I would highly suggest you check skirt clearance on the bench and then recheck AFTER the sleeve is installed in the block with Orings. Do one and see what happens. I say you need .007" or more skirt clearance to be safe. Let's see what these guys with the 210 engine failure finally figure out.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 12:37pm
When I started on wet sleeves AC had a paste in a tube...At an AC service school was told
to use the little can of plumbers pipe thread paste sealer...Was the same thing...Had the benefit of reseal and corrosion resistance.   I think that is why they said it was good for galvanize pipe. "because it had lead in it.."
Edited by orangereborn - 24 Feb 2023 at 12:07am
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 3:32pm
hopefully we get a follow up video this week with mention of the Dr
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 4:25pm
For those who haven't worked on a 426, they have 3 Orings, not the typical 2.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2023 at 7:57am
This is from the Reliance site tech tips section.
What severe consequences (bad luck?) to use too much lube.
I also wonder if Reliance has taken action about the second ring breaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2023 at 8:35am
I'm sure Reliance is using the updated second piston ring that A-C started using in 1978 or 79.  They say "lightly" applied sleeve Oring lube, which is what I have been preaching, LIGHTLY. Because excessive or heavier viscosity lube squeeze the sleeve and/or damages the Orings when assembling. I also contend that if they (and others) are using that .0025" to .005" skirt clearance dimension spec, that is too tight and is absitively too tight for non-piston cooled engines, as the piston swells up more under load and that .0025" clearance goes to ZERO and that's when the crap hits the fan.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2023 at 8:42am
   I agree one hundred percent, .0025 is nothing, no reason to be that tight.  Will cause undue friction even if it does not seize.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2023 at 10:17am
uploads/8665/15140ACD-4C20-41BC-BDA6-381384671C0D.jpeg.
Do you think something like that happened here
Edited by Mikez - 24 Feb 2023 at 10:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2023 at 10:37am
I don’t know why the picture didn’t come up. Sorry
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2023 at 12:55pm
looks like it ate a bunch of dirt.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 1:16pm
https://youtu.be/ptxyf8xTDX0
Well they pulled it down and are confident that it was the injection timing. I don't know if they got back to the Dr. Or not with what he said but sounds like they don't want his advice. Going to put it back together tight.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 2:39pm
I would like to know how much experience they have with the non piston cooled 426 or any AC diesel for that matter they said in the video they have 40 years experience and also say in the same video they rarely get to do the full assembly of the engine so can't have it both ways.The wise have spoken from experience it's their choice to heed it or hold their own. But on the bright side there's a 50/50 chance we can get a second why did it fail video for entertainment purposes. But what do I know I'm just a dumb farmer
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 2:40pm
So the testing of the pump wouldn't really do anything but waste time. The advance on these particular 210/220 AC pumps are nothing more than a start retard. They are at full advance by 1200-1400 rpm. A D21 is non advance pump, timed to 34*, these run at 36* with full advance, so very similar. I still say the shop put the weight carrier on wrong, resulting in the wrong position for the timing mark, not just off 180*, but off by a spline as well. All you had to do is apply air pressure into the #1 outlet, and turn shaft until it stops, look and see where timing mark is. Being too far advanced is why it was spraying over the piston bowl making it burn out around the crown, causing the ring ends to butt up. I actually think the shop that rebuilt this pump wrong in the beginning is actually what ruined the original sleeves and pistons. A DB pump has 2 positions to put the retainer on, thus having 180* off if wrong. These DC pumps have 24 splines, so it has 23 chances to get it wrong. I am not sure how in the heck they would have just happened to get it on 180* off, I still think it was off by a spline in addition to that. This is why we air time them after assembly. This tractor may have not been in too bad a shape before the pump shop effed it all up, and they just left it on is also a huge mistake. Now, I know they don't want to hear our solutions, but I'm putting this on for our own members, and many of you are customers of mine. Not everyone deserves the best lmfao! I'd like to hear who the 2 shops they used are. I am curious if the current pump shop noted where the weight carrier and timing mark actually were. I do agree with him in the fit is probably not the issue, they would all be scored, the one looks perfect.
Edited by injpumpEd - 26 Feb 2023 at 3:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 4:11pm
First off, it is very unfortunate that they have had a such a catastrophic failure in such a short time of operation on new parts. Like so often on this website, all the information isn't readily given, so coming up with an accurate cause or solution is more difficult. I would have assumed the injection pump was timed properly to the #1 cylinder. Their methodology was correct...align the crank pulley to 24 degrees BTDC and the mark inside the pump should line up. They even made sure the crank pulley was indexed reasonably correct and it indeed was. But it was never mentioned that they HAD to time it on #6 instead of #1. Like Ed just said, I don't think it could have actually been "timed" correctly because of the way the governor weight retainer is splined/attached to the pumps rotor. It isn't just #1 or #6. It can fit differently than that, so 24 degrees BTDC may have actually been 32 degrees BTDC. I could see in this last video the injector spray pattern much better than the previous video, and yet while it wasn't over the top of the bowl, it wasn't down in the bowl 100% either. I agree with them 100%, this was not a cooling system issue. Those engines don't "air lock" if you take your time filling the radiator, and I'm always cognizant of how many gallons I have poured into an empty cooling system. There is a proper cooling system capacity for every machine. The piston skirt clearance was checked on a good sleeve and piston and found to be within the .0025" and .005" range, which is within specs. I've found that within the range given, the nominal figure is usually near the center of the specs, which it was. This I can assure you: when that sleeve is installed in the block with the Orings, it certainly won't be any looser on skirt clearance. I was very surprised to recently find that according to my official A-C service manuals that a D-21 engines skirt clearance was .0065" to .009", while the 210/220 engines (and newer) are listed to be .0025" to .005".  How could this possibly be ?? The engines are identical in almost every way. Could there be a mistake in information transferred from the printing of one manual to a newer manual ??  I don't have any service bulletins from that mid 1960's to early 70's time frame to know if there was a legitimate tightening of these numbers or not, I was still in high school !! This I know from all my years of working on these engines, non piston cooled 426 engines are more prone to skirt scoring than any of the piston cooled engines.  And why wouldn't they be ?? If the pistons aren't bathed with oil from underneath to help keep them cool, they swell up more under 100% full load and the hotter the day, the cooling system runs warmer than on a Fall day, which can contribute to even hotter pistons, making the skirt clearances even tighter !!  I'm just saying looser is better on these older engines because of what I have seen over the years. We even had a 7030 one day on the dyno (an engine with 4 or 5,000 hrs on it) under full load lock up and stall from a scored piston !!  So it does happen and makes you want to puke when it does !!  So, ever since that incident and other stories I have heard from fellow dealers, .007" minimum skirt clearance has been my preferred spec to never have an issue, just like the D-21 engine. There were two types of piston cooling on these 426 engines. The early design was a small hole drilled in the upper main bearing saddle that was aimed at the underside of the piston just missing the connecting rods piston pin end. The second design was when they went to a 3-ring piston with the larger piston pin and pumped the oil thru a rifile drilled connecting rod to the pin bushing and then the cooling nozzle on top of the rod. Either way, piston temps were reduced by being constantly cooled with engine oil. I'm sure they'll get it back together and with things being timed correctly, it will be fine.
Edited by DrAllis - 26 Feb 2023 at 4:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 4:22pm
I hope they change those old style rod bolts, especially after having severe stress put on them trying to pull the scored piston down. Should use the ARP bolts from AGCO anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 4:25pm
They've been made aware of that and the turning around the conn rods with slotted rod bearings.
Edited by DrAllis - 26 Feb 2023 at 4:25pm
jeickman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 5:05pm
So if the timing was 180 off and too advanced by a spline wouldn't this affect all of the cylinders?  Was the scoring due to heat (piston and/or ring expansion) or fuel washing down the cylinder walls as the piston was coming to TDC before combustion. If it was the latter, I wonder if they had fuel in the crankcase?  I'm retired now but in all my years of being around this stuff I have never learned as much as I have from this thread.
Edited by jeickman01 - 26 Feb 2023 at 5:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 5:12pm
The pump timing itself wasn't 180 off. The actual pump timing must have been 10 degrees advanced and that is just a guess, but it was advanced, not retarded. The timing mark inside the pump was 180 off, or not really but it was 170 or 190 degrees off. Like Ed said, the splines on the timing mark part aren't exactly 180 off. So, anyway, they timed it on cylinder number 6, which if it was exactly 180 off, would have been fine. If it was a pump off of a 180 thru 200 tractor, it is exactly 180 degrees different because the timing mark inside the pump only assemble two ways...correct or 180 off. The D21/210/220 can assemble 23 different ways, I think. Anyway it is splined so many choices.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 5:46pm
24 ways, 1 right, 23 wrong chances lol! I feel they were right on the edge of too far advanced, which is why they felt it was "close" because it seemed to run pretty good. The holes in the nozzles can vary ever so slightly, and 2 inches away it can "lift" the spray pattern on the one hole, seems that is the area they like to start burning on pullers too, left front corner. Sometimes the installer just sets them in, and puts the bolts in and torques them. I always set them in, put bolts in just ran down, then turn the injector body clockwise to take up the "slop" in the bolt holes, then tighten them down. These little variations could lead to one cylinder being different than another by a small margin. Also the Roosa pump being of the variable beginning of injection variety, the cylinder to cylinder "start of injection" could vary a small amount, and being on the very edge already, puts it over the edge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 8:34pm
So, we don't actually know how the wrong timing mark positioning in the injection pump was discovered, do we ?? Did Jim's notice with the injection pumps marks aligned in the window it didn't have the rotor discharge hole showing at the #1 port ?? or did the whole injection system get completely installed and then the engine wouldn't start ??  At some point Jim's had to figure out the pumps lines were approx 180 degrees off. Maybe they made a phone call to their pump rebuilder and were told " well, just time it on #6 and it will be fine" ?? which of course would have been OK (on a DB pump) or maybe not OK (on a DC pump) ?? which if that was the case, that would have been poor advice to Jim's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 7:16am
One of the earlier videos he talked about having the pump supposedly put together wrong. Now, he may have had the shaft in the wrong place, but since that's how it was, pump shop corrected the issue, and now is not correct for out of position shaft and gear? Who knows. It was pretty obvious though I thought. I'm sure he will be sure it was someone else who messed up lol! If it was my customer, I would have instructed him on correcting the issue if there was one. You cannot time a Roosa correctly with a timing light either, unless you can check it at full load on a dyno. I remember him mentioning wanting to use a light to check timing. They do work great on an inline pump though. It's the way a Roosa or CAV varies the fuel, the beginning of injection changes with load, this is completely separate from the timing advance mechanisms. Most are speed advance, some have no advance (early 190, D21), some have load sensing advance (IH 282 in 560/656) Some use a speed advance with a light load advance on top of that, (7080/7580/N6)
Edited by injpumpEd - 27 Feb 2023 at 8:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 8:04am
Diesel timing lights just verify the advance is working. I trust them for nothing else.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 10:28am
Im sure they are out there, but I have never seen an engine time off of #6, or #4 or whatever, always #1. That said, if I sent a pump out to be rebuilt and at came back to set timing at #6 (theoretically possible on some pumps) and all of the service data for the engine was written to set at #1, that pump would have gone right back to the rebuilder to be assembled correctly.
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 10:46am
Used one in college. Never had to use one since LOL
1968 D15D,1962 D19D
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 11:25am
Interesting discussion in this thread. Very interested to see what they have found out in their next video update. This thread makes me glad I never had to look at anything newer than a WD-45 engine or mess with an injection pump.
Not to drag back up the o-rings but unfortunately they come in so many "colors" now it's hard to tell what one is by its colorant. Did the original manuals say what material and durometer they were, or just how to use the color to fit them up where they go?
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 11:32am
Yes the service manual said the orange oring was a silicone type and the black were buna n I believe.
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2023 at 12:05pm
