210 engine rebuild vid
Message Reverse Sort Order
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Topic: 210 engine rebuild vid
    Posted: 26 Mar 2023 at 10:01pm
I saw the U tube from the other guy pump shop. I didn't realize there's so many different ways to get a pump timed wrong internally. IT's too bad they didn't get to do the rework on the pump and show us what they found.
  Memory not what it was & only been 40 years since I had 1 apart !!
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2023 at 8:30pm
I assume you all have seen the tractor running again,wish him good luck this time.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2023 at 4:08pm
Roosa and CAV pumps are air timed on the work bench before putting on the test stand. It verifies the pump has been assembled properly. Nothing really magical about it. CAV technically says to pressurize with fuel, but since Stanadyne says air, we all use air, they invented the design afterall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2023 at 2:36pm
Think pump has to be on test stand to air time it. There you have the degree wheel to tell where you are. My 220 had to be air timed after changing shoes for increased fuel delivery. This timing info needs kept safe because you can't use original crank degrees mounting/setting timing.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2023 at 11:03am
No more on this thread? This is like when your favorite TV show gets cancelled.
The video from the Area Diesel Service guy was fantastic. I watched Jim's videos several times and the Area Diesel Service guy summed it up so well. Looks like about 6 ways to
assemble it wrong and get the timing off. Telling was the comment that about 1/2 the pumps they work on have that index tab broken off. Reusing this part could allow the mistake of being off in timing if they mesh the wrong splines. Wonder if that was the case here.
So Jim was still left with a knot in his stomach when it was go time with the repaired engine. I would also. How could the owner do a final timing check just before start up? What is this air time test Ed mentioned? What is spill timing, dribble timing? Can they all be done with pump installed (hope so). This engine had timing marks on the pulley. What was the intended purpose for this?  I get a knot in my stomach using a hand crank start on an gas engine with magneto. However, I know how to verify the magneto before committing to the crank.
There are pressure sensors to activate a timing light, but they don't have good reviews.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 9:45pm
Just watched the last video, the tractor sounds good but I’m also quite disappointed with the high thirty’s oil pressure. I would have expected closer to 50 psi on a full rebuild. Heck, my 4K plus hr XT runs 35- 40 psi at 2k rpm after she is warmed up. Maybe the 426 is totally different than a 301 when it comes to oil psi.
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 9:09pm
New video just went up today. I'd say she's running pretty good now!
There was a sister video that went up about potential injector pump failure stuff here:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2023 at 4:00pm
Yes sorry I watched them all to. Guess I didn’t pick up that it was suppose to be a comedy. I’d want to make sure it ran before I made fun.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2023 at 12:47pm
I think I've watched all the vids on this engine. To me the most telling thing was in the post mortem vid showing the injector spray pattern on the #6 piston.
Edited by exSW - 16 Mar 2023 at 12:48pm
Learning AC...slowly
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2023 at 1:11am
Link should work...
  It's from   Jim's Automotive Machine Shop, Inc.  About the Allis 210 that he rebuilt the engine once and then took it down to rebuild the second time after discovering problems stemming from injection pump / timing..
 and it is just simply a funny vid about timing your alternator... and the hilarious comments below the vid... Like, "Glad you didn’t put them on backwards or it would discharge the battery while running."
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2023 at 10:36pm
What was that little video supposed to be
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2023 at 9:30pm
Oh wow... that engine rebuild.  https://www.allischalmers.com/forum/uploads/242/013.gif  LOL https://www.allischalmers.com/forum/uploads/242/013.gif  LOL
timing the alternator belts ... 'failures to do this critical step may result in scored pistons and liners, cracked exhaust valves,
 and most of all, a bruised ego... 'https://www.allischalmers.com/forum/uploads/242/013.gif https://www.allischalmers.com/forum/uploads/242/013.gif https://www.allischalmers.com/forum/uploads/242/013.gif https://www.allischalmers.com/forum/uploads/242/013.gif
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 12:56pm
I don't know anything about these engines but I feel like I've learned quite a lot from those videos and this thread. Looking forward to the next one again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 8:12am
well, 20% over on a 210 pump is just a little over stock for a 220, which is the same engine. 20% over on roller setting is no surprise, but there was no way of knowing how far down the torque screw was set. But, the more you open up the roller setting on a RM pump, the sooner injection begins, when it is loaded to max pump delivery. Now, watching the vids of it pulling the little chisel, it was in no way working it to even stock full load, would guess it was taking about 100hp to pull it. Either the mark itself was placed in the wrong spot, or the retainer was put on completely wrong, which would be off a long way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 7:37am
The new pump shop claimed the pump was set 20% overfueled. No mention of the governor weight retainer being installed wrong as they weren't paying attention when they disassembled it, so it can't be proven, other than it couldn't be timed on #1 before.
WF owner View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 7:22am
He said something to the effect that they sent it to a different shop and he was disappointed that they just tore into it, without checking what the previous position was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 7:15am
Haven't watched the new vid, but did the shop ever say exactly what they found in the pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2023 at 6:44pm
The actual injection timing wasn't 180 degrees off. The pumps timing mark was approximately 180 degrees off, and more like 170 or 190 degrees off, putting the actual timing say maybe (a guess) 10 degrees advanced, which would put the spray pattern just up and out of the pistons mexican hat bowl. Being it was 180ish degrees off on the mark, caused them to have to "time" the pump on number 6 cylinder instead of number 1 cylinder. If it would have been EXACTLY 180 degrees off, timing on number 6 would have been fine.   Injpumped said there are 24 splines on the governor weight retainer where the "mark" is scribed. 360 degrees divided by 24 splines is 15 pump degrees per spline, which would transfer to 30 crankshaft degrees for one spline off.  Doesn't seem possible that it could have been that far off. It should have started terrible at that setting, unless I'm figuring it wrong and it was only 7 1/2 degrees advanced instead of 30 degrees ??
Edited by DrAllis - 12 Mar 2023 at 6:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2023 at 4:31pm
I watched this last video. I also saw the one where they rebuilt, installed the engine and ran it some. I disagree that the injection timing was off 180 degrees.
Back in the late 70's or early 80's, when were were pulling, we had some work done on the injection pump. When it came back, I installed it, as I had several times before. I had to use starting fluid to get it started, it belched gray smoke and it would hardly pull itself. Absolutely no power.
When I took the pump back to our pump guy, they had mistakenly timed it 180 degrees off. They fixed it, gave me some new banjo washers and I reinstalled the pump and it ran perfect.
If they had been that far out of time, I don't think the engine would have run like it did and never would have enough power to work it at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2023 at 1:18pm
New rod bolts-good.    Rotating rods because of slotted rod bearings-good.    Timing the injection pump correctly to #1 cylinder-really good.      Inj pump 20% overfueled only overfuels if the engine was loaded heavier. Shouldn't have normally been an issue EXCEPT if the pump was out of time, which it must have been.     Sleeve cavitation erosion won't happen because of looser piston skirt clearance. It happens because of wrong coolant without proper additives. Heavy Duty diesel coolant is the only correct type to use. Advanced pump timing (which we now think it was) would aggravate cavitation erosion, YES.       Valve guide seals, I never have and never will use. I don't care what they do. Both intake and exhaust valve guides are pressurized from underneath from turbocharging and don't need those.     Piston skirt clearance at .005" is by far better than .004" or .003" or .0025" which are all within specs.  D-21 specs of .007" to .009" would make me sleep much better at night.    Hope things go well for them this time around and I'm sure it will. Time to get farming !!!    Torquing head bolts under the rocker arm shaft isn't a problem when you have the correct special wrench to do it with.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2023 at 12:05pm
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 11:32am
Yes the service manual said the orange oring was a silicone type and the black were buna n I believe.
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 11:25am
Interesting discussion in this thread. Very interested to see what they have found out in their next video update. This thread makes me glad I never had to look at anything newer than a WD-45 engine or mess with an injection pump.
Not to drag back up the o-rings but unfortunately they come in so many "colors" now it's hard to tell what one is by its colorant. Did the original manuals say what material and durometer they were, or just how to use the color to fit them up where they go?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 10:46am
Diesel timing lights just verify the advance is working. I trust them for nothing else.
Used one in college. Never had to use one since LOL
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 10:28am
Im sure they are out there, but I have never seen an engine time off of #6, or #4 or whatever, always #1. That said, if I sent a pump out to be rebuilt and at came back to set timing at #6 (theoretically possible on some pumps) and all of the service data for the engine was written to set at #1, that pump would have gone right back to the rebuilder to be assembled correctly.
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 8:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 7:16am
One of the earlier videos he talked about having the pump supposedly put together wrong. Now, he may have had the shaft in the wrong place, but since that's how it was, pump shop corrected the issue, and now is not correct for out of position shaft and gear? Who knows. It was pretty obvious though I thought. I'm sure he will be sure it was someone else who messed up lol! If it was my customer, I would have instructed him on correcting the issue if there was one. You cannot time a Roosa correctly with a timing light either, unless you can check it at full load on a dyno. I remember him mentioning wanting to use a light to check timing. They do work great on an inline pump though. It's the way a Roosa or CAV varies the fuel, the beginning of injection changes with load, this is completely separate from the timing advance mechanisms. Most are speed advance, some have no advance (early 190, D21), some have load sensing advance (IH 282 in 560/656) Some use a speed advance with a light load advance on top of that, (7080/7580/N6)
Edited by injpumpEd - 27 Feb 2023 at 8:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 8:34pm
So, we don't actually know how the wrong timing mark positioning in the injection pump was discovered, do we ?? Did Jim's notice with the injection pumps marks aligned in the window it didn't have the rotor discharge hole showing at the #1 port ?? or did the whole injection system get completely installed and then the engine wouldn't start ??  At some point Jim's had to figure out the pumps lines were approx 180 degrees off. Maybe they made a phone call to their pump rebuilder and were told " well, just time it on #6 and it will be fine" ?? which of course would have been OK (on a DB pump) or maybe not OK (on a DC pump) ?? which if that was the case, that would have been poor advice to Jim's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 5:46pm
24 ways, 1 right, 23 wrong chances lol! I feel they were right on the edge of too far advanced, which is why they felt it was "close" because it seemed to run pretty good. The holes in the nozzles can vary ever so slightly, and 2 inches away it can "lift" the spray pattern on the one hole, seems that is the area they like to start burning on pullers too, left front corner. Sometimes the installer just sets them in, and puts the bolts in and torques them. I always set them in, put bolts in just ran down, then turn the injector body clockwise to take up the "slop" in the bolt holes, then tighten them down. These little variations could lead to one cylinder being different than another by a small margin. Also the Roosa pump being of the variable beginning of injection variety, the cylinder to cylinder "start of injection" could vary a small amount, and being on the very edge already, puts it over the edge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2023 at 5:12pm
The pump timing itself wasn't 180 off. The actual pump timing must have been 10 degrees advanced and that is just a guess, but it was advanced, not retarded. The timing mark inside the pump was 180 off, or not really but it was 170 or 190 degrees off. Like Ed said, the splines on the timing mark part aren't exactly 180 off. So, anyway, they timed it on cylinder number 6, which if it was exactly 180 off, would have been fine. If it was a pump off of a 180 thru 200 tractor, it is exactly 180 degrees different because the timing mark inside the pump only assemble two ways...correct or 180 off. The D21/210/220 can assemble 23 different ways, I think. Anyway it is splined so many choices.
