201-226 rotating assembly
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Topic: 201-226 rotating assembly
    Posted: 26 Dec 2013 at 10:48am
I have a rotating assembly left over to sell, I'm just finishing up the rods and should be ready to ship in a matter of a few days to a week.  It consists of new pistons, rings, rods, sleeves, O-rings, stroked crank for small main block(201-226, WC-WD45) rod bearings and main bearings.
Sleeves are 4 1/8 bore sleeves blasted clean, installed in a block and bored and honed, new O-rings.
new Pistons are Keith Black "Claimer" 4.155" bore pistons, KB9911HC
new Total Seal gapless ring package, "Claimer Series"
Rods are Farmall H rods, clearanced, narrowed tops, countersunk high strength cap screws, honed to size, balanced, bushed to .927" and honed for piston pins.
I have a choice of cranks, both balanced, noses faced and tapped (to hold degree wheel), flanges ground square.   5.4" stroke (10.2 to 1 compression ratio 292cid) with standard mains and .010" under rods, or a 5.5" stroke (11.2 to 1 compression ratio 297cid) with standard mains and rods.  Cranks are supplied with both main and rod bearings.
Ground camshaft, clearanced, blasted and scrubbed clean and a gear degreed to the crank for proper intake centerline.
In the older 201 blocks like the #31 casting things get pretty tight to swing the 5.5" stroke.  Later #40 blocks there's no issue, the WD45 blocks are also no clearance issue.  Slight clearancing will be required on instalation, a notch in the bottom of the sleeve for the rod to clear and possibly a slight notch in the oil pan rail.  On the earlier blocks a little notching in the web for the rods to swing past.
Cam bearings and a gasket set also supplied.
One package complete and ready for you to bolt together in your block with no custom machine work or additional parts needed. I put a few of these together and have half a set of parts left over and available.
$2750 for the complete package, core crank and cam required, or an additional fee for those items.  I'll work with shipping the best I can.
Marty
715-790-1869
Edited by wi50 - 26 Dec 2013 at 11:00am
This page was generated in 0.115 seconds.
